What is the best way to tighting the straps. Take out the supension? because when I tried I could not get a wrench in there to turn the bolts.
kawirider00
turn the sled on its side it wont roll itll sit on the knubs on the belly pan then u can slowly wrench them it takes a while cause its tight corridors
03viperguy
actually I got pissed enough so that I actually bought some of those slick craftsman box end ratchets. it fits sweet and you can ratchet it up fast
I HIGHLY recomend them to ANYONE with limiter straps that need adjusting
buy a 12mm gear wrench, cut it to three inches. this will swing clear around and miss the track.
SRXSRULE
- May 2, 2003
Flex Head ratcheting wrench is the Best way. ===SRXSRULE===
tsouth
- Feb 6, 2005
1/4 in drive ratchet works for me .not much room but you can do it
Junior
BETHEVIPER said:buy a 12mm gear wrench, cut it to three inches. this will swing clear around and miss the track.
bingo, I have a gear wrench cut off to about that length specifically for that job
