Yamitriple
Vincent
It's probably going to be fine. I used 1/4 plate on mine.
Yamitriple
Okay it just seemed extreme. I may hack a lityltle more off and try but just wanted to see what other people thought
Millinocket Rocket
How do you guys get the shims to stay in? Rivets or screws?
Vincent
I have after market plastic skis and in my case, welding was the strongest, and easiest option. Most do not need to go that route.
I use 1/4" plastic shims and drill a hole in the center of it then counter sink the hole for the screw to go and screw them to the bottom of the rubber stopper, I use screws with flat head so it fits perfect into the countersunk hole on the shim. I hope i explained that well enough.
Millinocket Rocket
Thanks, yeah I ended up putting a couple rivets in each shim and some marine Loctite PL adhesive to attach them to the aluminum saddles....We'll see how long they hold up. I kept losing them when I had my Viper. And I'm using 1/4" tapered shims too...
i use a peice of transport mud flap in all of mine but i do use the 09 mtx ski or the oe saddless ski and just put it together without the screw as it cannot come out until i remove the ski.
Yamitriple
I just used a small screw and an old drive belt. Although I think it may be a little much. Gonna half the size I have
4wealn
Ok for my clarification, the shim will go between the ski and the rubber stopper, on the back side of the stopper to help lift the front of the ski slightly as illustrated. My front of the carbide is touching but the back side is in the air.
I would like to add the shim, just confirming where it goes.
Thank you in advance.
Yamitriple
With mine I put the shim in between the rubber bumber and the metal “spindle”. Not sure if that’s correct but it worked for me
Vincent
Yes, you are correct on the shim placement! It will transfer more pressure to the back section of your ski and away from the forward leading edgeOk for my clarification, the shim will go between the ski and the rubber stopper, on the back side of the stopper to help lift the front of the ski slightly as illustrated. My front of the carbide is touching but the back side is in the air.
4wealn
Perfect, thank you guys.
