2001SRX=Fast
What things can i do to make it go faster. I want it faster every where.. holeshot to topend with alot of topend.
srxxx86
- Dec 31, 2004
proparly clutch it, jet it, and gear it. Studs also help out a lot overall. Clean your valves, carbs, etc. Basically, tune everything up. clutching is a BIG BIG factor, as well as gearing.
happy trails
happy trails
yamaholic22
Big Bore!!!
2001SRX=Fast
Whats a clutch set up... I was thinking about a 835 kit but i want something that is reliable.
snowprophet1
I never heard anything about the 835 big bore. Are they not reliable?/do they run good?
If you want to fly and be reliable.Simon's has a 780 kit that is 170hp with the stock exhaust.
hman
835 Bender BB
I have a 835 Bender BB with large volume Bender pipes and exhaust valves I can make you a good deal on. Send me a PM. or send me a phone # and I'll give you the details if your interested.
KianaF
- Nov 10, 2003
Bender Racing
I put the cold air kit with the Bender clutch kit and jetted the carbs went down one tooth on the lower gear and it is super quick Five sled lengths on my buddies xcr800 and he has everything done you can think of.
2001SRX=Fast
What did you jet tooo
cardguy
I have a clutch Kit for your SRX.
40-10Y Heel Clicker Clutch Kit. I used it one season.
100 US or 125 CDN
100 US or 125 CDN
2001SRX=Fast
I am looking for a set of aftermarket reeds if any one has
cardguy
lcool27,
Are you asking me if i still have it? (heel clickers)
yes i do, If you need more info and some pics, mail me at cardguy55@hotmail.com
Thankx
Thankx
Have you tried the hauck speed sheave? Supposed to gain 3-5 mph..?
hman
The reeds do very little with a stock motor,work better with ported cylinders but hardly worth the money.Same goes for the cold air kit.(noisy,inconsistent jetting).Tried them all!
yamyrider
your biggest bang for the buck will be clutching and studding.
Look at the tech page for clutch set ups.
knuckles
Any of you guys tried a set of heelclickers with a the white primary spring out of the RX-1 Heelclicker kit?
A friend of mine with an 02 SRX running heelclickers with a white primary (170-300) with a Bender helix 9770 BB (we think is around a 46/36 not 100% sure) and a red yamaha secondary spring with stock gearing. He tells me this is by far the best all around set-up he has had on the sled. Hole shot, midrange and top-end.
I have not had a chance to run against him with his set-up so i'll have to see now that we have some snow again.
