Paulver
What "new" carb will fit in an '83 Yammi Enticer 300? The carb that's in it appears to have a problem that isn't "fixable", and we're tired of the issue and trying to figure it out. It idles..... when it wants to, and it'll run like a top.... when it wants to, and it'll bog down on acceleration..... when it wants to!! Changing the pilot jet size up or down renders it useless! Won't start. No matter what, the plugs run black and wet. You can even smell the gas. Not sure, but I think a Kiehin is in it right now. The sled is in a friend's shop right now, so I can't look at it till Monday. The sled was given to me and I have no idea if someone fooled with the carb in the past or not. My instinct tells me that it's been altered in some way.
So......anyway, I think a new carb is in order.
Compression is 108 in one cylinder and 110 in the other. Don't know what the proper compression should be. If anyone can steer us in the right direction, I'd really appreciate it.
Thanks.
Thanks.
