Nasci89vmax
I can't find the torque specs and sequence for the headbolts. Also my gaskets don't say up or down, is there a way to tell which side goes up? Thanks
You tighten in two stages the first is 9.4 ft - lb then the second stage is 18 ft - lb then re torque after a good heat cycle. There is a picture in the link that shows the sequence.
https://totallyamaha.net/showthread.php/56774-SXR-cylinder-head-torque-specs-NEEDED!
A couple of bucks
Nasci89vmax
Ty guys, going to get fresh gas and give her a try!!
