newbie
valves are clean. carbs are clean. clutch looks great. what am i missing? plugs are new. br9ecs. i tested servo and it opens and closes
super1c
Super Moderator
Reeds? Belt. Clutch may look fine but is the towers clean and clutch moves fine. Clutch spring?
My guess is reeds.
newbie
reeds are great. sled has 1600 miles on it. ill check clutch again. when i run it it goes to 7000 rpm with alot of pull then motor sounds like it is struggling but doesnt bog just engine sounds different.
corrosion in the clutch. seen it a few times when getting old sleds that sat back out on the trails.
newbie
its gotta b the clutch cause everything looks great to me. i know nothing about clutches. i know the rollers look great and the spring is not broken, unless i have to take clutch off completly to inspect it. thx for all your help . ill pull clutch and check it out even though i dont know what to look for. also i noticed my compression was 120 120 and 122. i used 2 different compression tools and both were the same. is that low?
Its great the guy was helped but it truly should have been moved into the correct section.
SRXChris
Servo moves but is there any pull throughs? I wouldn't be to concerned with results of the comp test not to far off mines about 125.
drew24
Compression is good. Check the secondary clutch. I had a similar issue a couple years ago on my viper. I changed the secondary spring and it fixed it. Also be sure the valves aren't upside down. The big bevel goes down
Vincent
I'm thinken powervalves or weak clutch springs
JERSEYJOE
10-4 on the power valves or the secondary spring. Also the wrap must be correct to set the max rpm
Primary clutch corrosion
A couple of bucks
7000 Rs under load or no-load?
newbie
i put new fuel pump. new springs in both primary and secondary. new spark plugs . new belt. the same freaking results. reeds are excellent. carbs cleaned. on a stand i wot it and it goes to 6500 then drops to 6000 then slowly and awfully climbs up to and past 8k. the sled has 1600 miles on it and everything i replaced looked in great condition. what the little baby jesus am i missing????
A couple of bucks
I say the following w/ a bit of reservation ... remove belt and do the same.
newbie
no idea what u r saying
newbie
how do u test rectifier , coil pack or stator? thats the only thing i can think of. the only thing left
Yamahakid01
Hes saying remove the belt and rev the motor see if you can get over 7000 rpm's then we can try and rule electrical or mechanical.
Be careful not to overrev it badly !
Yamahakid01
X2 on that
