newbie
yeah. x3 . im not gonna run with belt off
			what do the spark plugs look like after you run it?
			newbie
the plugs look coco colored
			A couple of bucks
Well ....... while it's at 7000 Rs, can you at least figure out how to blip the choke then?yeah. x3 . im not gonna run with belt off
Plug chop at 7000 Rs?
							SRXChris
I've run mine on stand with belt off to see primary clutch movements.
			if plugs are tan to cocoa color then its running fine, problem is in clutchs, I see you say front clutch looks good, what about the rear clutch? is all the clutching stock? if you don't know post a couple pics of each clutch at different angles. the front clutch should have a color coded spring in it, that's a black spring with yellow/white/yellow markings on it, the weights should say 8dn20 on sides of them. the back clutch should have a black spring with a red dot on it and a 8bv-71 helix. post some pics, could be the sec is not wound up at all.
			A couple of bucks
In a previous thread of yours,(below) it was suggested that you mark the sheeves w/ a permanent marker to check belt travel. There were zero posts after that suggestion. Did you follow up or not.
https://totallyamaha.net/showthread.php/106412-2000-srx-700-bog
What ended up w/ your servo travel issue?
https://totallyamaha.net/showthread.php/106497-2000-srx-servo-working-properly
Mine is doing the same thing first ride out, pot and center plugs are perfect, mag was wet. Put new plug in, ride it a couple miles, looks like it was never run at all, but has spark.
			newbie
servo was working great. clutch springs all new. when i put it on jack stand i open it up all the way till it slowly hits 7500 rpm and when i back off throttle it wont take throttle until track stops. it makes weird power surge noises when i try to give it gas after reving it high and starts to slow down. its gotta b electrical. im pulling motor this weekend and putting new stator in.
Your Throttle Cable is too tight or TORS is kicking in from the TPS on the rack.
Powervalves adjusted? Maybe a bad needle valve or seal around the valve? If not that then maybe its a bad external coil, cap or plug wire. Is compression the same or close on all 3?
My power valves were out of adjustment, made the fix, but ran out of snow before I could test again.
