02 Viper blowing belts
hessracing
Iron Mountain Michigan
My buddy has an 02 viper and it keeps blowing belts, thought the problem was in the jack shaft we changed the bearing and the carriers and it is still doing it. This happens at high speeds, This viper has triple pipes on it, its clutched and has reeds does it need a torque arm? We will have to dig into it I do not believe it has any broken motor mounts but will have to do more digging. Any thoughts?
you need the engine brace on piped viper, also the pto motor mount is best replaced with one from a srx, has a extra bolt to hold it. if you still blow belts at high speeds, its likely because your chaincase gearing, a belt into overdrive has excessive belt speed and will blow for long periods of high speed, the fix is usually to simply gear up a tooth to slow the belt speed down.
I have all those aforementioned parts if you want to save some dough. Srx motor mount will be used, but the dogbone is all new in the package oem parts.
