marty f
Anybody have a stator, my lights were dimming last night when I was riding and when I stopped and tried to start my snowmobile there was no electricity at all on the sled
What kind of sled ?
I would check Ebay, but be careful buying an aftermarket stator for a Yamaha. Lots of reports that they don't work well.
I would stick with a Yamaha part.
Vincent
Well-known member
X2, stick to Yamaha stator
mod-it
X3.
And my local dealer was willing to loan me their fly wheel puller since I bought the stator from them.
s10mike
x4 i would only use a new oem yamaha stator. unless you wanna change it again right away
hessracing
Just went through all of this my wife's viper the hot grips were weak and the head lights also the tack would go goofy when you flipped the lights back and forth stator is the fix
marty f
Ok getting 2 long flashes followed by a short flash...three in total..so now whats that telling meSo been out riding around today and wveything is running tip top...can i run a test on stator and will it show if its going bad..jyst need to know how to test
Throttle position Sensor
marty f
i have it bypassed thats whats weird!!!
TPS is not the same as TORS
TORS = Throttle Over Ride System (or something like that)
TPS = Throttle Position Sensor
marty f
so hard hard is it to pull wire harness to check for rub thrus?
pretty simple. not much to it
marty f
can i bypass that too?
