hessracing
I got some vibration going on I'm not sure if I'm being over paranoid or if its normal i just lost my drive shaft bearing in my SRX so its making me nervous. It seems like it only happens at high speeds under a hard load like 70mph up. I put a different track on it last year it was a brand new take off of a Polaris has every 3rd window closed I don't know if that would have anything to do with it? It has a new bearing as well i tightened the chain in the chain case a little bit tighter that seemed to help a little bit I might try and tighten the track a little tighter too to see if that helps its only a 7/8" lug track any ideas?
