Yamitriple
Don’t want to add anymore weight to primary weights, how can I get belt to fulling “shift out”
A couple of bucks
What is your wrap at?
Yamitriple
89l weightscwith 6.1 g rivet 15 mm rollers standard spring with 1 engagement shim, 45 degree helix set to 60 wrap with standard spring. Eng 3600-3800 max rpm 8100-8200
A couple of bucks
If we are talking about the 97 Vmax700(a redhead) that is in your profile, take your helix wrap to 70. Your at only 81-8200 Rs anyway.
Vincent
Yes ideally your looking for 8300 to 8500 rpm
A couple of bucks
Not that this is the proper way to get to peak RPMs, but you will probably have to go to 80 to get close to 8500.
Yamitriple
Im running power inc center dumps. I also have a 46/41 helix I can try. Not much wiggle room on rpms. They fall off hard after 82
I think that 46/41 will get you a lot closer
Yamitriple
It’s supposed to be a 47 but the angle is a little shallow. I’ll try that at 60. Don’t really wanna mess with rpms too much
Yamitriple
Thanks for the help, it’s about 1/8 to a 1/4 shallow. Just was always told it should reach the very top. Is it different with Yamahas?
A couple of bucks
Yamitriple
Belt is new a rides where it should in secondary, little nubs on outside of belt are sticking over the edge a hair.
A couple of bucks
Have you SHARPIEd your clutch and went for a ride? If not , do so and snap a picture of where the Sharpie has worn off.
Yamitriple
Yamitriple
It’s not too bad but it still seems like I should be getting a lil more. Correct me if I’m wrong
Vincent
I think you chasing a non existing problem.
Yamitriple
Hahaha probably, just wasn’t sure if my belt should be squeezing all the way to the top or not.
A couple of bucks
Looks normal to me.
A couple of bucks
Now if your looking for better of the line performance, get that belt to ride higher in the secondary. It sounds like you are starting off ........ well in 2nd gear. This is based on your comments in post #10. Might even be 3rd gear if it is in fact at -1/4.
https://totallyamaha.net/showthread.php/79363-belt-sits-to-low-in-the-secondary?highlight=Circlip
Yamitriple
My secondary is right where is should be, I just wasn’t sure if my belt should ride higher in my primary at wot. Try and squeeze a little more out of it. If it looks right than it’s right I just didn’t know.
