OK, things I have replaced.
Head gaskets
Stator
Flywheel
Servo Works
Was using a W/W/W spring with Mr. Vipers SRX setup, only turned about 8100 RPM
Put in the next stiffer spring(stock)Y/W/Y, and didn't gain any RPM.
So, last night checked power valve adjustment with Mr Vipers help, and found they were all way loose, especially mag side.
Mag side had at least double the gap it should have, and the other two weren't far behind.
Hoping this was the problem all along, because new stator and flywheel had no effect.
Head gaskets
Stator
Flywheel
Servo Works
mod-it
Too loose = not opening all the way. Hopefully that fixes you up.
