Lester
I have a 2000 srx 700,sled has 5200 miles on it.The tach started fluttering,if you hold it a specific rpm it will flutter sometimes.,it will do it at idle also.any ideas of what is causing this ?
drew24
Check your wiring harness for a rub through. Usually it happens with the harness that runs under the motor and goes to the hood.
Lester
Thanks,I suppose the I need to remove the motor to properly check this.
Simonsweden
No you don’t you can pull it out under the motor and inspect. Look at tech page index
https://www.totallyamaha.net/showthread.php?t=75752&highlight=double+wall
drew24
No need to pull motor like stated above. Tie a string to the harness so you can pull it back under.
