Does your older age Yamaha sled use a 75 Watt stator system (like my 1999 Venture)?
If wondering, I have a recent thread (
https://totallyamaha.net/showthread.php/106601-99-vmax-600-deluxe-triple-headlight-bulb ) in progress. I'm still waiting for a few more LED bulbs to arrive and try out.... Thus, why this thread is active work-in-progress.....
As per my long thread, folks have told me:
- Stay under total 75 Watts. Way under using < 80% rule.
- Replace rear's 1157 BA15D tail light bulb with LED bulb - to free up more watts for front headlight Bulb Watts need. re: Upgrade the rear light before upgrading the front lights.
- Remember to take into account the LED bulb's "start up" wattage need. re: Bulb has running 20W but it might need short burst time of 35W (at immediate start up).
For me, I ordered / installed a single H4 LED "20 watt" Motorocycle bulb in my sled and its low and high beam work great. Perhaps 2 of these 20 Watt bulbs (for dual headlight system) will work for you? If not, perhaps you can use 2 x 18 Watt H4 LEDs for Motorcycle bulbs will work instead?
As one guy told me.... Buy lots of different LED bulbs and give different combinations a try.... And, remember to upgrade the rear light first - before upgrading the front light area.
For front LED "low wattage" bulbs:
- In Amazon for 20W, search for "
Safego Motorcycle H4 LED Headlight Bulb H/L High Low Dual Beam 20W X2 2000lm Motorbike H4 LED Lights Kit M4-H4"
- In ebay for 18W, search for "
Motorcycle LED H4 6500K HS1 Hi Lo COB Light Headlight Motorbike Bulb Lamp White"
Hope this helps....
