eye to clevis shock adapter
s10mike
holland michigan
Doe anyone know of a shock adapter for mounting an eyed shock into a clevis shock mount? Like the sxr and vipers have. Thanks
Thanks, that looks like what i need. I do not see where the hole is for the bottom bracket bolt on my sled. Is it down by the rubber steering cover? I do see a threaded hole down there. Seems far down, and would go over the plastic.
Mike, SRX has the bracket.
My SX is using Viper shocks, so have no pic of the bracket as I don’t use it with the Clevis shocks.
The reason you only see one threaded hole, is because the upper part of the bracket bolts into the bulkhead, where the clevis type shock would mount, then the bottom bolts to the threaded hole you see.
There is no upper hole, the top part of the bracket attaches to the eyelet.
Look up a 1997 700 SX in the parts Fische, you will see it there.
