Mike, SRX has the bracket.
My SX is using Viper shocks, so have no pic of the bracket as I don’t use it with the Clevis shocks.
The reason you only see one threaded hole, is because the upper part of the bracket bolts into the bulkhead, where the clevis type shock would mount, then the bottom bolts to the threaded hole you see.
