A couple of bucks
On the cogged wheels that drive your track(drivers), there would be nubs on those drivers. They would protrude through the windows on your track. Much like a positive drive system.
A standard driver does not have these. It is kind of like comparing a Philips tip screwdriver to a Torq tip. One slips, the other cannot.
fullcoda
No, I don't have them
03viperguy
I'm not sure if it applies to you with the longer track, but the clutch setup I have in my signature works amazing on my 121 viper. Was smoother on engagement, noticeably quicker bottom to top, and didnt lose anything anywhere. actually improved my mileage a tad. I ride groomed trail and cut across some lakes. fast northern NH trails, mostly logging road width, 40- 70 mph
A couple of bucks
Yes you will more than likely need to lighten the rivet in the tips of the clutch weights.so do you suggest that I should put a lighter rivet in the tip? Would this increase engagement rpm?
No the engagement will not change.
You should use a gram scale to insure the weights are all the same exact weight. The following link is to the same one I currently have. It is rugged and self-protected when not in use.
https://www.ebay.com/sch/34088/i.html?_from=R40&_nkw=tuff+scale&_sop=15
