Yamitriple
Looking to get rid of my center dump power inc's and go for one of the above mentioned brands, does anyone have a set they would like to part with? 150-200 price range, must have flanges. springs and gaskets arnt a big deal. Title is in order of what I'd like most(left to right).
I think your list is good, except I would swap Bender with SLP, I have both.
A couple of bucks
Are we talking about your 97 redhead?
Yamitriple
We are indeed. I dont think that the work I'm putting into these center dump pipes will be worth it at the end of the day, so I'm going to switch directions and try for a better set of pipes or take the sled back to stock and run a thinned head gasket with reed notch and bored silencer
I would keep searching for better pipes. I had 2 red 1997 700 SX's at one time.
One stock, one with Bender pipes, thinned head gasket, ect.
We raced them against each other many times.
The difference between them was about comparable to a stock 700 against a 500 twin.
Night and day.
Night and day.
A couple of bucks
That is EXACTLY what I did w/ my 97 SX7. It would have been no match against my sons 99 SX6 w/ PSIs on it.run a thinned head gasket with reed notch and bored silencer
A couple of bucks
That 99 SX6 w/ PSI trips on it.... sounds like a top fuel dragster. AKA......bad @SS!!!!!! Each exhaust note ...."cracks". Very similar to a TF dragster.
A couple of bucks
We got those PSIs free. Traded a stock set-up for those.
https://totallyamaha.net/showthread...iple-pipes-for-stock-pipe?highlight=Trade+psi
Yamitriple
Found some nice slps working on a deal rn will keep you guys posted. Will likely need clutching help depending on this guys knowledge and what he was running. Gonna try and get his weights and helix
Strokn4yamz
with all experience ive had the Power Inc end dump were about the only ones that actually made any power, when they went under Hauck bought out their stock and has since took it over. Thats where i would go or focus a search.. Pat/PI developed a lot of exhaust over the years together. you can pick a set up for about 300 or so but its well worth it. those along with thin headgasket or just give it a haircut, reedspacer or notch, carbon reeds, clutching/gearing that thing will be right up there with the srx
Derbidge 11
Seems like you know these pipes well.. I'm having trouble dialing mine in.. running a little lean on PTO and center.
changed jets to 147.5 on all 3 haven't touched needle height and pilot to 47.5
Derbidge 11
Power
Derbidge 11
Power inc
