SRXChris
Removed chaincase to change all bearings inside, jackshaft, drive etc. I had removed to bolts holding caliper on and set aside. Reinstalled everything and gave the brake lever a squeeze and nothing now just spongy or no pressure. Do i need to bleed? Didn't touch while it was off the disk and went on just fine so caliper wasn't moved or brake lever. Leak somewhere? No fluid evident as well.
A couple of bucks
Is there fluid movement in the reservoir when the brake is applied?
SRXChris
Finally get to look at it better today. I will check if it's being moved.
SRXChris
Checked it today and all is good. Lever has pressure and reservoir is full. New problem now(starting to hate this sled) no spark on cylinder 1.
