SRXChris
Removed chaincase to change all bearings inside, jackshaft, drive etc. I had removed to bolts holding caliper on and set aside. Reinstalled everything and gave the brake lever a squeeze and nothing now just spongy or no pressure. Do i need to bleed? Didn't touch while it was off the disk and went on just fine so caliper wasn't moved or brake lever. Leak somewhere? No fluid evident as well.
