Yamitriple
So I bought a set of hauck hushers to replace my center dump power Inc's for my 97, just seeing if anyone can tell me a thing or two about em. Guy is including a clutch setup but would like to know if anyone has knows good setup and what rpms they turn at aswell as agood trail jetting. Gonna keep the motor stock besides reed spacers
Yamitriple
Been doin some research on here an found some old stuff, can someone confirm if older hauck pipes are actually just CPR simmons?
Yamitriple
Also went straight through hauck and got there recommended jetting. Nothing on clutching tho so far
Yamitriple
A couple of bucks
Yamitriple
That's the same info I got from hauck, but alls they could tell me about clutching is it takes there clutch kit. Cant seem to find anything on clutching with yamaha parts
MURDER YAMAHA
VIP Life Member
Those hauck pipes appear to be Simmons CPR pipes.
I think Hauck relabeled simons Pipes.
Yamitriple
That's what it appears from reading around on here. Anybody ever run them? And know a good clutch setup? I know they run around 9000 rpm but hauck wont tell me what's in the clutch kit lol just want me to get out my pocket book
MURDER YAMAHA
VIP Life Member
I have them on my black 700 with heel clickers, and have a buddy with them also. Let me see what I can find for you.
MURDER YAMAHA
VIP Life Member
Here are some jetting specs from Mr. Viper that he gave me in the mean time...
I used 148.8 mains, 47.5 pilots, f/s at 1.5 out, needles at 3.5,3.5,4.0. 9100-9300rpm, 93 octane fuel. So, if you use lower octane fuel youll need to be richer on specs to make it live!
Yamitriple
Appreciate it big time! And yes where I ride I generally use 91 ethonal free. So I'll just go with 150 main 2 turns on screw and i planned to raise needles a full clip across the board. Will either use 45 pilots or 47.5 if it sounds hesitant. Dude I'm getting pipes from says he is going to send me the clutch setup he had in sled. Whether it's right or wrong I do not know. Just wanted some info before hand to knowHere are some jetting specs from Mr. Viper that he gave me in the mean time...
MURDER YAMAHA
VIP Life Member
OK, here is what we are currently using in my buddys SXR.
8CR Weights, 13.3 rivet inside hole
W/S/W primary spring
45 Helix @ 70
This turns around 9000 RPM if I remember correctly.
I would bump the primary spring up one, to a Y/S/Y.
This is all assuming you have stock rollers, using 8DN belt, stock short cover primary.
45 Helix @ 70
Yamitriple
45 Helix @ 70
Okay I have a y/s/y primary spring and I have a 45° 46/41° and a 51/43° to choose from. I also have some 89L 8ch and 8ek weights. Then whatever this guy is sending with pipes. I should be able to get it dialed in with at least some of these options. I have 15mm rollers and stock secondary spring
Yamitriple
Does the jetting I said I was gonna run sound reasonable for 91 octane?
A couple of bucks
Just thinking ahead here ...... with what I can see that you have available, your going to need good rubber. To get the most out of the "Yamaha clutch kit" and those pipes, a ...... not stock .... track will be needed.Okay I have a y/s/y primary spring and I have a 45° 46/41° and a 51/43° to choose from. I also have some 89L 8ch and 8ek weights. Then whatever this guy is sending with pipes. I should be able to get it dialed in with at least some of these options. I have 15mm rollers and stock secondary spring
Yamitriple
I have a fairly new 1 inch track with 96 1.175" down the middle. It's in good enough shape that I dont plan on changing it this season. If it's not enough then I guess I'll just have to cope till next year. I also have adjustable lighting rods and I'll have non slip drivers aswell
Yamitriple
Unless somebody has a used good condition track that's already loaded for sale in my area I dont see it happening
Yamitriple
Also I gotta ask, do these pipes deliver good performance on the trail? Lol
MURDER YAMAHA
VIP Life Member
Yes sir, triple pipes compared to stock single is night and day on a redhead.
Try racing a stock one once your done, amazing difference.
Yamitriple
I cant wait, I was really dissatisfied with the center dumps I had personally. It didmt seem to put out what I thought it would. I hope these ones ripYes sir, triple pipes compared to stock single is night and day on a redhead.
