Yamitriple
Maybe someone else can chime in about the maxx performance springs.
Are they for short cover or long?
The spring itself is quite a bit longer than a ysy or stock. About 1.5 inches. It has less twists tho. How will I know if it isn't for short cover? Will it just not fit or will it fail later on
Yamitriple
Also was wondering if maybe I retune the 8ek if I should run thoseThe spring itself is quite a bit longer than a ysy or stock. About 1.5 inches. It has less twists tho. How will I know if it isn't for short cover? Will it just not fit or will it fail later on
Yamitriple
Just match the weight of the 8ek to whatever the 8ch weights are
If it was me, I would put in what he had to start with. Should get you close, and fine tune from there.
Yamitriple
I got a question for you murder yamaha, could you maybe snap a pic for me so I can see the order of the pipes on motor and also exhaust flanges to see which way is up
Yamitriple
That's perfect thank you. Do u know of your head if the flanges should angle down or up?
