25 tooth hyvo for SRX??
tomseal6
Brevort, MI
Will a 25 tooth hyvo gear fit in a SRX chaincase? Is it available?
Wanting to swap to a 1.00 track with 1.25 inch studs and want to run 8 tooth drivers.
25/37 gears brings the gear ratio back to stock at 1.67 ratio
Stock gears 23/38 with 9 tooth drivers is 1.66 ratio
A 25 for SRX has smaller diameter splines/jackshaft.
If anybody wants to trade please contact me.
I did a 24 or a 25 in my apex which is the same basic case. I bought both but don't recall which one I ended up using.
I went to a 26 in my apex, has the larger shaft.
I went with 07 Attack clutching which has much lighter fly weights and is a lot more responsive. I just didnt have any pull on top end with the stock gears so I went to a larger top gear. I have a 25 for Apex to trade.
That gear is still available at Wahl not sure about Oem availability, got some lower gears this spring for my srx. I also put 8 tooth extros on the drives lots of room.
