Just pulled the carbs on my Vmax 500, it was only running on one cylinder.
When I opened the top cap I found that the bolt which fasters the slide assembly to the throttle shaft had backed itself out and was loose.
Can I apply blue loctite in this area when I reassemble? There is no lock washer on the bolt.
Thanks,
Hank
Thanks,
Hank
