srx700pilot
I picked up 98 srx, carbs hadn’t been cleaned in forever. I’ve   Cleaned carbs 4 times now and continue to have upper mid to top end poser loss.   Any powder or high end it bogs.   I have spare carbs off a 700sx. Can I try those to help rule out carbs?    How can I diagnose between fuel issue vs clutch issue?     It has good throttle response and power, until what seems like high rpm whether  fuel or clutching.  Thanks.
			Whats the RPM its running at, at wide open ?
Sounds more like clutch problems...
srx700pilot
I’ll check when I get home tonight.   I know my 00 and 01 run about 8250.  This one is probably only in the 6k range. In my mind I feel like it goes then the rpms get up there and it falls flat, bog, and no power.      I just don’t know how to diagnose between fuel, clutching, maybe power valve.  I don’t think it would be so responsive if it was power valves ?
			A couple of bucks
Blip the choke at the problem RPMs.How can I diagnose between fuel issue vs clutch issue?.
Yep, that should tell you if its a carb problem or not.
SRX's run best around 8400, I would shoot for that number.
Im sure you have a clutch that's stuck.
I would take both off and look for problems.
A couple of bucks
If that doesn't do anything, empty an entire can of starting fluid inside the primary and immediately take it out for a run. If that does it, the clutches need attention.
			Yamahasrx700
Sounds like a power valve issue
			A couple of bucks
I hate to be Mr. Obvious, but ...... are the PVs clean and adjusted properly?
			A couple of bucks
You beat me to it.
Remove the PV servo cover and look for excessive slack in one or more cables. If you find any cable with a lot of slack, it's most likely pulled through at the other end. Throttle response will be the same with our without a broken PV, but you won't reach peak RPM at WOT.
Your target RPM is 8400-8500 at WOT.
When cleaning the carbs, did you pull the needle seat under the float and clean the inlet screens? These are often over looked.
I think that could very likely be causing the problem
I was a bit surprised you did not mention these "top hat" screens.
Hope all is well, SSB.
A couple of bucks
Your target RPM is 8200 at WOT.
WOT should be 8500, according to the tech pages.
srx700pilot
Thanks for all the input.    I havent had a chance to get back to it during the week.   I’ll try all the recommendations hopefully tomorrow or Thursday and post results.
You're right. I'm not sure where I got 8200.
A couple of bucks
That the max a twin should spin.You're right. I'm not sure where I got 8200.
Hey I'm a poet and didn't know it.
All good
Id still stick with your day job..... lol!
A couple of bucks
Probably so.
