SoDakDave
Hello all. I'm new to this machine (and snowmobiles in general) and am trying to understand this rear suspension.
At the rear of the sled are the control arms on either side with bushings above and below the control arm. When I lift and settle the rear bumper, there's about an inch of space between the... lower control arm? and the bushing on the upper stop. If I put a bit of weight on the rear bumper, I can get that stop to "bottom out". Is that bottoming out the suspension? or is that the point at which the rear shock really starts to activate and work? I can really push down on it and start to get a bit of spring past it there, but not much. Even when I get and sit on the sled I don't really get any further travel down. That said, when I lift on the rear bumper, there's not a whole lot of travel before it starts lifting the track off the ground, so it's not like the weight of the sled is taking up all the suspension...
Any explanation of how this system is supposed to behave on this sled would be really appreciated.
