Hey guys, a quick question. Can you replace the speedo driveshaft bearing without dropping the track and suspension?
Thanks in advance
Thanks in advance
Yamahakid01
It is possible but the shaft has to be in good shape it clearance for the shaft is tight.
Thanks Yamahakid01, LOL, getting lazy in my old age
Yamahakid01
I got mine to move enough on the shaft to slide between the bearing and use a pitman arm puller to get mine off.
just make your track as loose as possible to make install easy.
Vincent
Well-known member
Done it many times. Follow above advice.
Yes, loosen track all the way, remove speedo housing.
Loosen the 2 allen head set screws on bearing(access under tunnel)
Then bearing will come out twords speedo housing side.
If its super rusty, can be difficult..
