700sxvermonter
I posted recently that my tachometer and speedometer weren't working. Also the odometer isn't working . actually every now and then they do work. Any ideas on what's going on? It's a 2004 sx viper ER. it has a battery and starts fine with the electric start or pull start. It runs great just isn't showing the info on the dash and I would like it resolved
Vincent
Well-known member
Loose, broken, or chaffed wire(s) would be my guess...
700sxvermonter
Ok next thing to check will be wiring harness thanks
May want to play close attention to under the handlebar pad, and above the key switch area.
700sxvermonter
thanks ill do that when I get a minute to get in there
700sxvermonter
So I pulled the handle bar padding off and inspected the wires there and so far nothing looks chafed but after I made sure all connectors were plugged in and the inspection the tach and Speedo started working again so I am going to carefully go thru every wire in that cluster and check them all! Thanks a lot murder yamaha I think you put me in the right direction!
Good to hear !
...as I usually chase my tail for half the day when looking for problems.. Lol
700sxvermonter
Yeah I don't usually get that lucky either. Lol but hopefully I got this narrowed down thanks again
