I'm getting about 75 miles to a full tank on stock SRX with 8200 miles. Everything has been rebuilt including top end and carbs gone through, stock jetting.
Can bad reeds cause poor mileage?
Sled is running really good, other than poor mileage there are no problems
Vincent
Well-known member
How do your reeds look?
Have to check them yet.
A couple of bucks
If it was fine when to stored it last season, it could very well be degradated needle seats.
I have another identical carb rack I know is good.
What item # in the Fische is the needle seats?
Are you talking about the fuel screw o ring?
Lester
#33 and 35 on fische,if you want to check blow into carb fuel inlet, it should hold pressure.if not thats your problem .
So blow into the fuel inlet nipple to see if I cant blow through it?
lol, unfortunately, that's not too far off what most look like after a lot of miles.
I like to buy the entire needle and seat assembly, and new orings when doing it, just for peace of mind.
I have a good spare carb rack.
super1c
Super Moderator
Good catch on reeds! They have caused me problems more then once.
Lester
if you can blow threw them then needles are leaking,I would blow through the spare carbs before installing.If they are leaking its using a lot more fuel,.
Spare carb rack gone through. Clean as a whistle since a bottle of sea foam was ran in motor before carbs were taken off.
New pedals and reed blocks are in.
Thanks buddy. I knew there was a reason I picked those reed valves that year. Still sitting in a drawer in the box u sent me.
Lol.
So,,, I guess I had a combination of problems? Probably the needle seats more than anything though
Sorry, that was Jeff that sent me the reeds. Lol
That was back in 2014 for the 2013 season, the year Peyton Manning choked like a chicken in a huge blow out. Seahawks VS Broncos
Maybe we can get a contest going for next season. Who is in?
