newbie
if this is clogged will it cause high rpm bog? also what is best way to get off, there is no room to work with the thick wire in the way
I read through this again did we talk about the dreaded harness rub through? Also I’ve seen some TPS issues with The SRX. Do a search on TPS a few good write ups on this issue.
last question... what happens if i unplug tps and run it?
