So, I just had a major snowmobile problem and was wondering when you guys do you maintenance? I usually do mine in the fall. Example - power valves and carbs cleaning, track and carbide inspection, suspension greasing, and fresh gas and a general inspection of the sled. I like the fall so I know the sled is good to go for the upcoming season.
If I need do big project, like a track, studs or bushings or bearings, that is done in the spring, if it can wait.
Also, how often do you clean the power valves?
