White & Nerdy
I bought an '03 Viper a few weeks ago and one of the reasons I bought it, was the newish ice attak track it has. When I went to look at it, the guy had it out in his yard so I could test ride it. The suspension seemed a little soft, but aside from that, everything seemed fine. When I looked in the skid, being packed with snow, I never noticed the SERIOUS damage to the inside of the track that I found later. Turns out the rear shock mount was rubbing on the inside of the track. I pulled the skid out expecting to find broken parts, but everything looks okay. The bushings have all been replaced, the w arm has been welded, but everything seems straight. The only thing, is the rear shock was set way looser than it should be. This sled was ridden by the guys daughter, and I'm guessing he set it that way since she probably doesn't way 100 pounds. So, the questions: could this much damage be caused by the rear shock preload being set too light? What else should I be looking for? Is this track useable? Thanks!
