EVOVII_SWE
I'm planning to replace my track in the off season, I would also like to replace my drivers with a no-slip version, I was looking at Wahl Bros racing but I'm not really sure which ones to get, I would like to keep stock size:
If that is correct, I'm looking at 02-579 or 02-580, the latter says "Machined for Yamaha RX-1 application" but what is the difference, both seem to have 8BW-47531-00-00 as stock?
I tried to search but couldn't find anything really
- Should I have the 1 1/16 - 1 1/8" hex shaft version?
- Should I have 9 tooth? (don't have my sled close to check)
- Do I replace the two in the middle and keep the outer two stock?
A couple of bucks
1. Yes on the 1&1/16 - 1&1/8
2. If you are replacing them anyway, I'd go to an 8. It'll give you more track options. Plus there will be better snow evacuation.
3. Yes. Replace the inner two w/ the positive drive Wahl type drivers. Leave the outside two stock.
EVOVII_SWE
Thank you
Regarding number of teeth, does that change the pitch or how do I get more track options?
If I change to 8, can I get the outside ones in 8 as well?
Would I need to change the chain sprockets to compensate since 8 would give me a shorter gearing effectively?
A couple of bucks
1. When you order you drivers, you'll need to specify the number of teeth and drive pitch. Most common here is the 2.52 pitch and more than likely what is currently on your sled. Your track options open up because you can go up to 2" lug.
2. Yes all drivers will need to be either all 8 or all 9 tooth drivers.
3. 23/38 w/ a 70 link chain and 9 tooth drivers is what was stock in an 01 SRX. I wouldn't change a thing. I think that's perfect gearing coupled w/ 8 tooth drivers for an SRX. It's not going to take quite so long to top out.
A couple of bucks
2.52 pitch is 2 & 52/100ths of an inch from center of drive lug to center of drive lug. Basically... 2.5 inches.
EVOVII_SWE
Perfect, thank you, then I'll need to see if I can find the outside drivers in 8 tooth configuration, I guess that will be OEM Yamaha?
