MR. X
Hey guys,
Did someone ever tried to change headlight bulbs of a 2001 and up V-max, mmax for a led? If yes, how did you do ?
Do you think this add will be a simple plug and play of this is a nice way to get trouble?
https://www.cafr.ebay.ca/itm/LED-H4...rentrq:d2c3157a1730aad34f9d702cffffe028|iid:1
i did it on a 1997 et410 witch is the same type electrical system, 12v ac, with rock's toyz kit.
this is the review i did on them.
https://totallyamaha.net/showthread.php/96434-rockztoys-LED-hid-review
this kit made 5 seasons before the bulb burnt out the low beam setting. when funds allow i will be ordering another kit.
MR. X
thanks Maim !
What I have done, use a LED H4 bulb less than 25 watts each.
Then, run the wire from the unused reverse beeper to the hi/low switch.
I have done it on 2 sleds, both work great. Reason for running the wire is because you need clean DC power to run LED bulbs. Reverse buzzer wire has it.
Jack99
agree....
And use motorcycle LED bulb that has fan inside light assembly cavity - to melt snow off its front lens surface.
Wiring Picture and LED bulb I use are below....
