led conversion
What I have done, use a LED H4 bulb less than 25 watts each.
Then, run the wire from the unused reverse beeper to the hi/low switch.
I have done it on 2 sleds, both work great. Reason for running the wire is because you need clean DC power to run LED bulbs. Reverse buzzer wire has it.
agree....
And use motorcycle LED bulb that has fan inside light assembly cavity - to melt snow off its front lens surface.
Wiring Picture and LED bulb I use are below....
