406chevyss
I am curious if anyone here has cut the shock mounts off on the trailing arms and flipped them to gain ride height on their srx.
Sent from my SM-N986U using Tapatalk
Good to hear that some has tried it. The only thing I saw that might be an issue was the steering hitting.Buddy of mine did that on his when he was riding it in MT. Worked fine. When he moved back to MN he cut them off and flipped them back to the factory height
guys have used sx viper front shocks with a bushing from betheviper back in the day.
I did that to mine. Worked great.
Thanks for the info. I was wondering if you could get me a measurement of the radius rods for the viper from where the hiem threads in to the outside. I'm going to end up making my own. Also curious how much taller the viper ski spindles are compared to the srx.Center to center is 17.5” on the viper shocks. I put viper ohlins on my srx and made new upper shock mounts. It was a little bit of work and some machining but it’s done and I love it. I also put viper rears on it as well. That was the easy part. You will want to use the entire front end from a long travel sled to keep the geometry correct etc.. trailing arms, radius rods and steering rods
