Little Boy Blue
Hi everyone,
My 2001 MM 700 has a small problem. When running powder at 1/2 to full throttle the machine acts fine. However, when you back off the gas to 1/8 through 1/2 throttle and attempt to go around something, the engine loads down and does not want to pull. Snap the throttle open and the engine will clear itself and it will run to 8300 rpm. On trail running is good throughout the throttle range. When in powder with the engine acting up, just find a previously run track and the engine clears up.
The sled is stock with the exception of reed spcers. Clutching and jetting is set for sea level. I ride at 0 to 3000 feet. Track is a yoko 1.1 "
Any suggestions.
Chris
Any suggestions.
Chris
