Need help with SX700 Driveshaft bearing replacement
sloTJ
Cambridge, WI
I have my whole sled torn apart and doing driveshaft bearings. I picked up a “All Balls” driveshaft bearing kit and basically don’t know where some collars belong, the o-rings and what order this all goes back together. I have a skinnier and a wider collar that I think fell down after removing the back half of the chaincase. Where do each of these go?
There are two additional collars on both the jackshaft and driveshaft that I left untouched.
Please look at these pictures and let me know where these collars and o-rings belong.
Thank you so much!
5703C74C-4808-47B5-B6AD-DB67D4D7640B.jpg9E40A323-2350-45D2-A10F-F85CECFE8488.jpg374A48FF-2634-4AE0-81DE-5AAB84435359.jpg38E30097-2251-449B-8379-7FC3C1582AD1.jpg
The parts you have in your hand are 20 and 32.
They go on right behind the gears, bigger one on top, smaller on bottom.
You will see that if it isn’t correct, the chain won’t be straight, as the gear spacing will be wrong. May even rub on the cover.
