reed spacers?
MYRODMAN
new boston,ill
Is there an advantage to notching reed plates and also installing reed spacers on a 2000 600 vmax with a red head triple engine?
Notching helps but is not as good as spacers.. I had mine notched and after removing my jugs this fall, I observed top Reed stopper still restrict the rear booster ports . Only way to completely eliminate boost port restriction is with spacers.
spacers, easy to make yourself if you are up to it. after the amount of cracked reed stops I've found, I'm not a fan of notching them.
Royal Distributing sell a real nice spacer kit for cheap!
I don't believe they are required if you have Vforce reeds. Just what I've read on this forum, I have no experience with them
