CameronGreen
I have a 2002 Vmax 700 triple, sled is all stock and has a single pipe, i was wondering what i could do to boost the sound, can i put on some triple pipes, and if so what do i need to do with carbs and stuff, and if that doesn’t work what cans do you run and what do you have to do to the carbs for those?
bore out the stock can, sounds greats and adds about 4 hp.
https://totallyamaha.com/snowmobiles/aaTECH/silencer_boring.htm
Vincent
Drilled can does sound great, though 4 hp mite a bit of a stretch
Back in the day we Dynoed the mod and it made 4hp in the mid range but only 1 or 2 on top.
sideshowBob
Before installing tripple pipes on our 99 SXs I performed the Stock silencer mod with good results.
The Red Head tripples liked a little less restriction from the exhaust silencer.
In 1997 Dynotech tested a stock 700 and got 111.8 hp @ 8250 rpm. After installing a less restrictive Bender silencer on the same 700 they got 114.7 @ 8500 rpm...gaining 3 hp.
Drilling the stock silencer reduces back pressure which gives a performance increase similar to the Bender silencer.
Vincent
That makes sense
devinzz1
heres sound clip of a bored out exhaust. it was also running around 8500rpms with this setup.
https://youtu.be/hv2H5hNy5uY
https://youtu.be/v2x-Gl15Ncw
northern srx
Lifetime VIP Member
Long time no vid-ya!!!!
devinzz1
due to unforseen events. parents divorced, me never getting sled registered in my name over the years, the sled being stolen back yadda yadda yadda. i no longer have the vmax.
riding a new sks 146 now. BUT. i loved that old triple. getting the itch to buy another and start a new build. looks like most of the old members are still on here ahaha
northern srx
Lifetime VIP Member
Ouch... glad to see your still tearing it up!!!
Vincent
Great videos! Sounds stout!
MR. X
Nice sled. What was your suspension set-up for those easy wheelies?
devinzz1
poo skid and iqr track. sled had full lightweight build, custom clutching and 8t drivers along with many many other things
EDIT. actually at the time of video it was viper skid with drop brackets and kimpex 1.3" lug track. everything else stock
