Repeated issues with OEM Yamaha in-tank fuel filters
sloTJ
Cambridge, WI
I repeatedly am having issues with the factory OEM fuel filter coming apart along the adhesive and then sucking up grit and clogging my pilot jets over and over! Anyone else have this issue? What’s a better fuel filter to use instead? Thanks.
only ever seen this once on a sled my brother got instead of money he was owed. i use the kimpex ones as well and they have been lasting.
I've had this happen. Sometimes it is hard to get the hose on, and I end up pushing too hard causing it to let go. To fix it, I gently squeeze the pipe so it is slightly oval shape, then it will friction fit itself back into the hole. Also, before installing the hose, I chamfer the end more rounded, so the hose slides on easier without cutting into it.
