rx1007
I was looking in the tech section and went to Turks clutching/jetting section. He noted using 14.5 rollers for a 2000-2001 sxr 700 in addition to "above per trail or racing." I see it lists 97-99 sx700 trail and 97-99 sx700 racing. I'm assuming these are single pipe specs. Trail spec says stock weights while racing states 8ca weights. My question is ,are the stock weights for the 97-99 or the 2000-2001? I'm also looking for all of these parts including the 51/43 helix. Does anyone have these they'd like to sell? Lastly, what is the twist for the stock or silver secondary spring he has listed? I am going to do the stock exhaust mod and head gasket mod as well.
Correct, those are single pipe set ups. It would specify what pipes if its a piped set up.
fu racing
Just did the same set up as turks page for my 2001 vmax with 14.5 rollers,headgasket ,2 shims muffler ,headgasket ,51/43 and amazed how much it changed ,now revs 83 8400 not 8900 and pulls hard.
rx1007
So what weights should I use? The 8 CA for the racing setup with the necessary rivets, the stock ones from 97-99 (8CH) trail(as listed) with appropriate rivets, or stock ones from the 2001 with rivets? Everything else is going to be done. Can't wait to see the difference. Thank you for all the help.
I like the 8ca and 8ab set ups for the 700 triples.
rx1007
I was thinking of the 8CAs as well. These come bare correct? I would still need to add the rivets Turk listed correct?
Always come empty. Turks set ups work really well.
I have a set of 8ca ‘s that I can load up for using 4.5 inner 3.1 tip. I can as look through stuff and see what else I have. Pm me if your interested.
vdubracer33
where did you find a 51/43!! cant find one anywhere
Should be all kinds of these around. Yamaha used these for years and years on RX-1 and Apex. 03 through 18
s10mike
I use the apex helix on my sx700r, works good
