Washington
Hey
I am having a hard time getting a 99 Phazer to run right. I have had the carbs off twice, already. Everything is clean. I have a question about the black plugs in the float bowl. It has one plug unlike the earlier model Phazers which had two. That's the way it came. The online Yamaha illustrated parts list shows one plug in the center hole. Is this correct? It sounds like there was some problems with the documentation for the pre 1998 Phazers and it has been talked about in a couple of other places online. I should have paid more attention when I took it apart. The center hole it plugs in at the bottom of passage which is drilled so it vents into the float chamber making the plug seemingly ineffective. The plug is in remarkably good condition for it's age.
It is hard to start, barely runs (very rich, lots of smoke) and I am getting kinda frustrated. If you know for sure where the plug goes let me know.
If anyone has any other ideas on things to check I would like to hear them. I am running out of ideas. This may be a little too detailed of a problem to address in a forum.
Thanks for any help.
John
John
