1989 Exciter crank bearing
MikeWalters
Saskatchewan, Canada
Anyone know part#s or where to get crank bearings? Clutch side outer most bearing, has some play and its a bit noisy. Split the case to replace all the seals and discovered it.
BEARING
93306-30718-00 (replaces 93306-30711-00)
might have to look around for nos as it is showing up discontinued on the parts fiche. i tried to get aftermarket for a 78 et340 and had to go oe as no one made it aftermarket.
