Can anybody help me with this. I put new plugs in and rode for about 2 hours. Pulled them when I got home and the mag and pto side plugs look normal, actually rich, but the center plug looks almost new/untouched. I used an ignition tester and they are all firing normally. I thought maybe the center wasn't getting good fuel/oil, but I then I thought if that were the case the jug would have burned down after two hours of riding. A bit baffled by this one.
I little warm.....
A couple of bucks
That center one might be washed clean..... mabey.
Jetting?
What does the carbon on the piston top look like?
Jetting?
Mac
Welcome to the Forum. Did you clean the pilots pre season. Something is leaning it back a touch.
Thank you Mac. I've been coming here since I bought the sled last winter, I've just been sitting quietly in the background and trying to learn more about the mighty triples. I hadn't ridden since back in the 80's on my Enticer 340.
Anyways, yes I cleaned the carbs and power valves before the season.
Jetting?
I'll have to take a look at the pistons. Everything under the hood is stock as far as I know.
A couple of bucks
Another possibility is an unmetered air leak on center cylinder.
Top hat in center hole might be restricting fuel flow .... ethanol snot plugging up the plumbing.
I checked all the boots, and I only run NE91..no ethanol for this guy
Top hat in center hole might be restricting fuel flow .... ethanol snot plugging up the plumbing. There's a screen in there that can become restricted...
A couple of bucks
jclee71
i just went through a similar issue, it was the spark plug, I swapped the plugs around and the lean condition followed the plug, not sure why but this new plug reacted strange, dont know why but when I put a used plug in it showed a good burn, dont know if certain new plugs take some time to reveal the cylinder burn properly
