TobyRX1
Can someone HELP me and tell me what year motor is in this SRX ? The number is 8DN 005610. is it a 2000 ?
PLEASE HELP and THANK YOU !!! And I apologize if it is listed on the site somewhere but can't find anything
on listing of years.
What numbers are on the cylinders?Can someone HELP me and tell me what year motor is in this SRX ? The number is 8DN 005610. is it a 2000 ?
TobyRX1
Cylinder # is 8DN00
695 cm 3
Y-1
695 cm 3
Y-1
TobyRX1
Any HELP would be Great , THANK YOU !!!
1998Cylinder # is 8DN00
695 cm 3
Y-1
Probably the biggest and most important differences on the 700 SRX's engines was the CDIs and Stators.
-The 1998 and 1999 SRXs had a CDI with three separate square plugs, single headlight on sled, and NO TPS on Carb rack
-2000 had a CDI unique to that year and a twin bulb headlight
-2001 and 2002 had a CDI with two rectangular plugs, twin bulb headlight, and a TPS on the carb rack
TobyRX1
Thats what has me stumped is it has the duel light and the rectifier and relays
that are the same as my 2000 I had . It does have the short power valve cables like
the 98 but the electrical part of it is what had me thinking. Its a pieced together sled
from about every year so just wanted to go by the numbers to see if that could
get me where I could figure it out. When looking at the power valves with the cables
and the first thing I thought was 98 but anyway ? THANK you for the help.
The electrical can be swapped from a '00-'02 onto a '98/99 engine with the right parts. I did it to mine using a flywheel from a '02 SX-R red head with the higher watt stator.You could have the pickup coil mount moved on the 98/99 engine cases by welding in a piece of aluminum and redrilling new holes for the pickup.This would allow use of the smaller flywheel off the '00-02 but using the SX-R flywheel is much easier.
