Is it possible to adjust the needle position on a 99 Vmax SX with the 600 triple without removing the carbs and disassembling the rack? I had a look, and it seems like I have to lift the arm that connects to the rack out of the carb, to slide the pin out to gain access to the plate that holds down the needle. If that is the case, thats a bit of a pain in the butt.
