Shawnyxtc600
- Dec 26, 2021
I just did the rings on my yamaha 600 xtc and now i have a coolant air lock. Tried lifting front of sled but motor gets too hot after a while and the hoses dont get warm or the coolers. When I tale bleed screw out it shoots sky high. Did that for about 2 hours today or felt like it. Nothing helping it. And there is no thermostat
snowman_959
- Nov 8, 2021
Did you try filling it through the rad cap first, then the reservoir?
Shawnyxtc600
- Dec 26, 2021
Yes I filled it through the cap first respvor was almost empty than it filled up on its own
snowman_959
- Nov 8, 2021
My yamaha has a bleed screw on the rear and on the head. Did you try bleeding it through the head too?
The rear bleed screw is the one you want to bleed with.
Shawnyxtc600
- Dec 26, 2021
Didnt know there was a bleed screw on the rearThe rear bleed screw is the one you want to bleed with.
Wheres that at
Shawnyxtc600
- Dec 26, 2021
Just a cross over tube in tje back
snowman_959
- Nov 8, 2021
It's on top the tunnel in the corner. There should be a black rubber over it.
Shawnyxtc600
- Dec 26, 2021
Thank you I'll check first thing tmrIt's on top the tunnel in the corner. There should be a black rubber over it.
Sometimes you have to remove seat nuts and raise the seat rear to get at the bolt.
Shawnyxtc600
- Dec 26, 2021
And this is on 1998 xtc vmax 600 twins?
Shawnyxtc600
- Dec 26, 2021
I found the bleed screw. Do I leave the front jacked up? Or do I let down the front and jack up the back?Sometimes you have to remove seat nuts and raise the seat rear to get at the bolt.
Just leave it sit normal.
Shawnyxtc600
- Dec 26, 2021
Spending hours at it and it jist keeps shootings coolant all over the place.
Shawnyxtc600
- Dec 26, 2021
Do I wait until it stops shootings coolant out or what? Went through 2 jugs so far thanks dont mean to be a pestJust leave it sit normal.
Shawnyxtc600
- Dec 26, 2021
Seems like it just squirts out until it empties the system. Than ingots refill it. Than same thing agajn
As soon as coolant starts to come out, put the bolt back in.
super1c
Super Moderator
Raise the back of the sled bleed bolt to just higher then the overflow coolant bottle. Sled off unscrew the rear drain plug (coolant should not be comming out). Slowly add coolant to cold fill mark. Then slowly lower rear of sled till coolant comes out bubble free and replace screw. No way should you have used 2 gallons and sled should not be running. A chain fall or even a wrachet strap suspended from garage ceiling comes in handy. Then start sled and check side coolers. If still not taking tip sled side to side will force air to move. Then repeat above process and check again.
Water pump belt OK?
Shawnyxtc600
- Dec 26, 2021
Thabks alotRaise the back of the sled bleed bolt to just higher then the overflow coolant bottle. Sled off unscrew the rear drain plug (coolant should not be comming out). Slowly add coolant to cold fill mark. Then slowly lower rear of sled till coolant comes out bubble free and replace screw. No way should you have used 2 gallons and sled should not be running. A chain fall or even a wrachet strap suspended from garage ceiling comes in handy. Then start sled and check side coolers. If still not taking tip sled side to side will force air to move. Then repeat above process and check again.
