So my big rear shock is definitely in need of a rebuild, is there a way to test the small rear shock without taking the skid off the sled?
My sled has the aluminum (I assume rebuildable) shocks.
So, I'm looking to probably get both rear shocks rebuilt I'm quite sure the front shocks are still good but I'm wondering how I can tell for sure, what should I look for, or what measurements should I take to confirm?
I would be happy to simply remove the skid and pull the shocks off to avoid paying shop labour costs for that part but the truth is that it was pretty difficult to install the rear skid even with the help of two buddies. I'm not sure if there is a trick to getting it bolted into the tunnel, we did front bolts first, then rear then middle which were very difficult to line up.
I do see a small part on the rod on the big rear shock which has a rust "bubble" maybe the size of a dime, maybe an inch from the end of the rod, would that make the whole shock toast needing to be replaced? If for some reason I was wanting to replace the rear shock what are some good economical options here in Ontario?
A small side note, I also noticed the cap on the coolant reservoir seems fairly loose, as I understand it there is a brass pressure relief valve on the bottom of the cap which connects to the small maybe 4" long hose on the top, however I don't see the cap holding much pressure at all before coming off or leaking. Should I just replace the cap with a new (tighter?) one?
