Shawnyxtc600
- Dec 26, 2021
Air lock. Everyone gave me lots of advice. I am very thankful. I tried every bit of advice.
Lift front of sled than the rear. Open bleed screws, rock the sled side to side. Run it with cap off. Check water pump belt. She builds lots ofmpressure so the pump should be working. I am about to give up on the air lock. I did reuse the old head gasket when I put new rings in the sled. Used a brand new base gasket. The used head gasket seems to still be in good shape. I cant figure it out. Its building pressure somewhere in the system
